ddrowe
May 24, 2018Aspirant
Sigh! SMB shares can't enable on my RN314
My ReadyNAS 314 has just started to be inaccessible via SMB. AFP works fine from my Mac, but my Windows Media Centre cannot connect to the SMB shares any more. Not sure how long this has been going...
- May 24, 2018
OK, so I managed to restore my SMB service. I downgraded my firmware to 6.9.2 to see if that would do anything. Nope (just a few crypitic errors in the console). So I upgraded back to 6.9.3 and viola.
I can turn on SSH now too.
Retired_Member
May 24, 2018Doing a community search for "SMB disabled" is bringing up lots of threads dealing with the same problem and there is no panacea for the reported trouble. Except factory reset of course :-)
The following link to me looks the most promising trying not to use the big hammer. Good luck.
- ddroweMay 24, 2018Aspirant
That link seems to refer to a full root disk. Mine has 2.5G free. :-(
- StephenBMay 24, 2018Guru - Experienced User
A filling OS partition can cause this (and was the cause in the thread Retired_Member links to) - but with newer OS-6 releases you should see some alerts telling you that the OS partition is getting full. So perhaps look for those.
If the OS partition is filling, then it is possible to clean it yourself if you are comfortable using linux shell commands.
It you aren't experienced with linux shell, then the best way to avoid the "hammer" is to use netgear support (my.netgear.com). They can resolve this for you (including rebuilding your SMB configuration). They won't support used NAS though.
If you purchased the NAS between 1 June 2014 and 31 May 2016 then you have lifetime chat support via my.netgear.com. Otherwise, you would need to pay. Ask for per-incident support, it should be sufficient for this.
- Retired_MemberMay 24, 2018
Nice and interesting solution.
I would wonder whether anybody could comment on why downgrading and upgrading again was fixing this and what might have go wrong during the first upgrade, though.
With a good explanation at hand it might be worthwile to improve the upgrade process hence avoiding the "smb disabled"-issue moving forward to future firmware releases.
