ELBaudoin
Dec 02, 2015Initiate
Slow performance after upgrade my ReadyNAS 314 to 6.4.1
I am experiencing serious performance issues after upgarde to 6.4.1, relating to opening files from the server. I don't know what to do. Can somebody help me?
- Dec 03, 2015
Please let us know your case number if you have a support case.
Were you updating from 6.4.0 or an older release?
Can you send in your logs (see the Sending Logs link in my sig)?Edit: Are any of you using the anti-virus service? If so, on 6.4.1 does performance return to normal if you disable the anti-virus service?
WarrenT
Dec 03, 2015Tutor
Hi,
I have 3 RaedyNAS 312 devices and all are extremely slow after upgrade from 6.4.0 to 6.4.1. Almost unuseable.
- mdgm-ntgrDec 03, 2015NETGEAR Employee Retired
- ELBaudoinDec 03, 2015Initiate
Hi mdgm,
I was using the anti virus service. And yes, when I turn it off it goes back to normal! So it seems that is the issue for me. What should I do now? Will there come a fix where I can enable the virus scanner again without issues?
We will look into this problem.
Btw are you using a torrent app? If so, that may be the problem.
For now you could stay on 6.4.1 with AV disabled or if you prefer enable it and downgrade back to 6.4.0.
- WorliDec 16, 2015Tutor
I upgraded my RN314 from 6.4.0.
Yes, when disabling the Antivirus the performmance is absolutely fine and as expected.
When having Antivirus active, it is impossible to work. Therefore I turned it off.
kind regards
Christian W.
- BrianL2Dec 16, 2015NETGEAR Employee Retired
Hi Worli,
Thanks for your contribution to this thread. NETGEAR will soon release a Firmware that will address this issue.
Kind regards,
BrianL
NETGEAR Community Team
