ELBaudoin
Dec 02, 2015Initiate
Slow performance after upgrade my ReadyNAS 314 to 6.4.1
I am experiencing serious performance issues after upgarde to 6.4.1, relating to opening files from the server. I don't know what to do. Can somebody help me?
- Dec 03, 2015
Please let us know your case number if you have a support case.
Were you updating from 6.4.0 or an older release?
Can you send in your logs (see the Sending Logs link in my sig)?Edit: Are any of you using the anti-virus service? If so, on 6.4.1 does performance return to normal if you disable the anti-virus service?
WarrenT
Dec 03, 2015Tutor
Hi,
I have 3 RaedyNAS 312 devices and all are extremely slow after upgrade from 6.4.0 to 6.4.1. Almost unuseable.
mdgm-ntgr
Dec 03, 2015NETGEAR Employee Retired
