ELBaudoin
Dec 02, 2015Initiate
Slow performance after upgrade my ReadyNAS 314 to 6.4.1
I am experiencing serious performance issues after upgarde to 6.4.1, relating to opening files from the server. I don't know what to do. Can somebody help me?
- Dec 03, 2015
Please let us know your case number if you have a support case.
Were you updating from 6.4.0 or an older release?
Can you send in your logs (see the Sending Logs link in my sig)?Edit: Are any of you using the anti-virus service? If so, on 6.4.1 does performance return to normal if you disable the anti-virus service?
lenscooter
Dec 05, 2015Aspirant
My ReadyNAS 202 was also rendered useless after upgrade from 6.4.0 to 6.4.1. I could not access files on the NAS from my PC, although backup prgrams worked.
The problem completely went away after I turned off the antivirus option in my RN202. I trust there will be a quick fix to this!
