ELBaudoin
Dec 02, 2015Initiate
Slow performance after upgrade my ReadyNAS 314 to 6.4.1
I am experiencing serious performance issues after upgarde to 6.4.1, relating to opening files from the server. I don't know what to do. Can somebody help me?
- Dec 03, 2015
Please let us know your case number if you have a support case.
Were you updating from 6.4.0 or an older release?
Can you send in your logs (see the Sending Logs link in my sig)?Edit: Are any of you using the anti-virus service? If so, on 6.4.1 does performance return to normal if you disable the anti-virus service?
cleveland_rocks
Dec 21, 2015Aspirant
I am also experiencing very slow performance (on OS 6.4.1) with the AV service enabled. Shutting it off returned the file system to its normal efficient self. It's a pity, since the AV found a few infected files that Kaspersky missed.
Hope this is fixed in the new patch.
BrianL2
Dec 21, 2015NETGEAR Employee Retired
Hi cleveland_rocks,
NETGEAR is working on a fix but there's no ETA when it will be released.
Kind regards,
BrianL
NETGEAR Community Team
