ELBaudoin
Dec 02, 2015Initiate
Slow performance after upgrade my ReadyNAS 314 to 6.4.1
I am experiencing serious performance issues after upgarde to 6.4.1, relating to opening files from the server. I don't know what to do. Can somebody help me?
- Dec 03, 2015
Please let us know your case number if you have a support case.
Were you updating from 6.4.0 or an older release?
Can you send in your logs (see the Sending Logs link in my sig)?Edit: Are any of you using the anti-virus service? If so, on 6.4.1 does performance return to normal if you disable the anti-virus service?
webZplus
Dec 30, 2015Star
I'm slow (pun intended) glad I found this, since the upgrade to 6.4.1 my ReadyNAS 202 has become so slow it's unusable, I can't wait to turn off the Anti-Virus and try it again, yesterday it took me over 1 hour to open two small files (and excel spreadsheet and a word doc) and then save the word document as a PDF - ReadyCloud via the app on my Laptop (Windows 10) also sits there 'Connecting...' for hours and never actually connects... I'm hoping that the Anti-Virus thing might fix that too - note to self don't ever perform upgrades prior to holidays or extended time away from the office where connectivity is required :-(
- BrianL2Dec 30, 2015NETGEAR Employee Retired
Hi webZplus,
I suggest that you turn off the AV feature or much better, install the latest Beta Firmware that addresses the issue that you encountered.
Kind regards,
BrianL
NETGEAR Community Team- webZplusJan 11, 2016Star
Thank you Brian, turning off the Anti Virus immediately brought the speed back... now if only I can resolve the issue of ReadyCloud unable to connect from my laptop (windows 10 and ReadyCloud Client v1.9) I'll be happy :-)
- BrianL2Jan 11, 2016NETGEAR Employee Retired
Hi webZplus,
Great! This AV issue is still being addressed. With regard to your ReadyCLOUD issue with your Windows 10 PC, you could check similar or relevant posts in the community that may help. Check this page out.
Kind regards,
BrianL
