cmchoi
Nov 09, 2012Aspirant
SLOW RAID Level X-RAID2, 6 disks (with dual redundancy)
I have a Pro 6, I create volume with 5 disks (3TB each). After sync completed, I added 6th disk as dual redundancy. It is very slow to restrip after 6th disk is added. Is this normal? It will ta...
mdgm-ntgr
Nov 09, 2012NETGEAR Employee Retired
Restriping can take a long time particularly when migrating from single to dual-redundancy.
What services do you have enabled? Any add-ons installed. Disabling unneeded services should help speed up the syncing a bit. If a service is using a lot of CPU that can really slow down resyncing big time. Recently a resync was crawling at 1MB/sec on my Ultra 6 (has a much slower CPU than your Pro 6). After disabling a service that was hogging CPU resources the resync sped up to 30 something MB/s
