cmchoi
Nov 09, 2012Aspirant
SLOW RAID Level X-RAID2, 6 disks (with dual redundancy)
I have a Pro 6, I create volume with 5 disks (3TB each). After sync completed, I added 6th disk as dual redundancy. It is very slow to restrip after 6th disk is added. Is this normal? It will ta...
Nov 10, 2012Guru - Experienced User
I have the LAG type set to LACP in the switch (GS724T in my case); you also have to put the two switch ports into the group.
On the NAS I have LACP with xmit hash policy of layer 2 + layer 3.
I don't believe the order matters, my recollection is that both devices fail over to non-teamed operation if the LACP setup fails.
