Cyanara
Jun 21, 2015Aspirant
Slow RAID0 to RAID0 on 314s with bonded gigabit
Hi, I've just set up two 314s in a small business. Each has 3 new WD Red 6TB drives in it, set up in RAID0. Both have two new <3m CAT6 cables going into the gigabit switch, and are bonded with adap...
mdgm-ntgr
Jun 21, 2015NETGEAR Employee Retired
1. If performance is key and you want to limit any performance degradation over time as much as possible create new shares with bit-rot protection disabled and snapshots disabled.
2. If you SSH in and run the 'top' command you get some good output on CPU utilisation.
I probably would have gone for the 516 for this use case. Furthermore with a single client you would like only saturate one link.
- Dec 25, 2018Retired_Member
