Cyanara
Jun 21, 2015Aspirant
Slow RAID0 to RAID0 on 314s with bonded gigabit
Hi, I've just set up two 314s in a small business. Each has 3 new WD Red 6TB drives in it, set up in RAID0. Both have two new <3m CAT6 cables going into the gigabit switch, and are bonded with adap...
Cyanara
Jun 22, 2015Aspirant
Thanks for that. I disabled both of those but I don't know if it will take effect while it's in the middle of a backup. I'll experiment with multiple client downloads/uploads later when it's finished.
At any rate, the sending NAS currently has over 70% CPU idle, while the receiving NAS has over 50% CPU idle, so I can probably rule that out as a problem.
Both generally have less than 100MB of RAM free, but I imagine that's not likely to be an issue unless most of that was already used up before I started the transfer. Once again, I'll check that later after this initial backup finishes.
- Dec 25, 2018Retired_Member
