Cyanara
Jun 21, 2015Aspirant
Slow RAID0 to RAID0 on 314s with bonded gigabit
Hi, I've just set up two 314s in a small business. Each has 3 new WD Red 6TB drives in it, set up in RAID0. Both have two new <3m CAT6 cables going into the gigabit switch, and are bonded with adap...
Cyanara
Jun 22, 2015Aspirant
I turned off AV when I saw how slow the backup was going. I assume any improvement should have become apparent immediately, but there was none. That same backup is still going though. 3TB takes a while at this speed :p
The protocol is Windows/NAS, which may have higher overheads. I was keeping it simple while I worked out how set up backups. Do you recommend any protocol in particular?
On a side note: I know ReadyNAS can't be directly attached to a computer, but can you connect two of them together by USB? I'm just thinking about the fastest means of restoring up to 16TB of data in the event of a disk failure.
- Dec 25, 2018Retired_Member
