Cyanara
Jun 21, 2015Aspirant
Slow RAID0 to RAID0 on 314s with bonded gigabit
Hi, I've just set up two 314s in a small business. Each has 3 new WD Red 6TB drives in it, set up in RAID0. Both have two new <3m CAT6 cables going into the gigabit switch, and are bonded with adap...
deploylinux
Jun 22, 2015Aspirant
make sure the switch you have connected the nas's to supports etherchannel/lacp, configure the switch and nas to use a load balancing algorithm that is best for your destination...usually, if same source -> same destination, it will only go out one link...which means the max bandwidth will be about 80-85Mbps, and with a 316..75MBps would be rather close to that. If you have a managed switch, look at the port transfer stats to see if the traffic is being balanced evenly between the two links..I doubt it, I suspect that is your limiting factor here.
- Dec 25, 2018Retired_Member
