PeacekeeperNL
Mar 17, 2014Aspirant
slow ReadyNAS Duo v1
Hello everyone, I am trying to find a sollution for a friend of mine, who owns a ReadyNAS Duo v2. He has his own business, and uses the NAS to store his files. Connecting to the NAS from the laptop...
Mar 17, 2014Guru - Experienced User
There is an update check built into frontview, that should locate the current firmware
You can also download it from http://kb.netgear.com/app/answers/detai ... 28sparc%29 and manually install it. If you do that you need to unzip the download (you don't install the zip itself).
