voidness's avatar
Jun 09, 2014
Slow rsync between esata and /data
Because I do not have a Gigabit Switch so I thought I'd transfer data from my external HDD (NTFS) drives to /data with rsync (all done on the NAS by ssh into the NAS as root and run the command), but the speed seems to be quite disappointing
7177991340 100% 14.76MB/s 0:07:43 (xfer#1, to-check=862/864)
What do you think is holding it back ?, I have done some research and I believe it has something to do with the btrfs file format ? and because of this format it needs the CPU to do something to the files (xor-ing or something) and thus the CPU is holding back the speed ? or the speed is slow because this is NTFS , top did show high CPU usage for mount.ntfs ?
Top is showing this
top - 18:33:46 up 24 min, 2 users, load average: 2.64, 2.75, 2.05
Tasks: 123 total, 2 running, 121 sleeping, 0 stopped, 0 zombie
%Cpu(s): 32.3 us, 55.7 sy, 0.0 ni, 0.0 id, 5.0 wa, 0.0 hi, 7.0 si, 0.0 st
KiB Mem: 507240 total, 481764 used, 25476 free, 81304 buffers
KiB Swap: 1047420 total, 0 used, 1047420 free, 203536 cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1912 root 20 0 30352 1740 388 R 26.0 0.3 5:03.21 rsync
1910 root 20 0 30456 2228 880 S 25.4 0.4 5:23.83 rsync
1712 root 20 0 5628 1300 668 S 22.5 0.3 2:55.49 mount.ntfs
850 root 20 0 0 0 0 S 6.4 0.0 1:03.65 md127_raid5
3 root 20 0 0 0 0 S 2.6 0.0 0:05.46 ksoftirqd/0
1480 root 20 0 0 0 0 S 1.6 0.0 0:25.09 flush-btrfs-1
6 root -2 0 0 0 0 S 1.0 0.0 0:07.71 rcu_kthread
236 root 20 0 0 0 0 S 1.0 0.0 0:09.94 kswapd0
1630 guest 20 0 85916 12m 4356 S 1.0 2.4 0:08.74 transmission-da
1479 root 19 -1 173m 25m 5804 S 0.6 5.1 0:21.43 readynasd
1706 root 20 0 5368 1580 1056 R 0.6 0.3 0:07.07 top
Am I doing something wrong, or this is expected ? I did however tried copy files from my OS to the NAS via a Gigabit Switch earlier and the speed was steady around 40MB/s - I thought rsycn between esata and /data internally should atleast match that ?
  • Voidness,
    You have not given a NAS model# or F/ware rev. I guess you have OS6.
    If HDD was plugged into a PC, could you do a similar data copy for comparison.?
    Thanks,Marto
  • I have a ReadyNAS 104 / FW 6.1.8 - copying files from my own Linux Box > Gigabit Router > NAS I did achieved expected speed ~ 40MB/s, but not rsync locally between esata and /data
  • StephenB's avatar
    No.
    [quote="voidness"or the speed is slow because this is NTFS , top did show high CPU usage for mount.ntfs ?[/quote]. Again no. SmallNetBuilder.com got ~35 MB/s in their backup test to ntfs (though they were probably not using rsync).
    I am thinking that you should probably try NFS to make the backup.
  • The CPU is simply saturated by using the combination of (full-)rsync and ntfs
    5.0% waiting => theres not much time spent waiting on the disk, your not I/O Bound
    the nas is spending roughly 1/3 of its time in each rsync process, and in the ntfs process
    ntfs performance is cpu bound in the linux implementation, AFAIK. I simply think that code isn't very optimized (and hard to do, as they had to reverse engineer it. If i recall correctly, ntfs still involves userspace parts, which means there is a lot of kernel-userspace-kernel transition needed.)
    rsync does heavy-checksumming on default, to see which parts of a file might have changed.
    You're using rsync from the webgui as abackup job? then i think you can't modify the options...
    if you can, try "--sizes-only". This will degrade rsync to a copy, that will assume files haven't changed when they're the same size in destination as in source, but this should speed up the process quite a bit...
ProSupport for Business
