NewL1fe
Apr 01, 2012Aspirant
Slow transfer speed and way to much bugs..
Hello Im new with ReadyNas, but been using it for sometime now tho :) Ive got loads of bugs so far and the rescan for ReadyDLNA has been bugging constantly and now it's totally not working, from...
NewL1fe
StephenB wrote: Are you seeing any errors in the SMART stats under disk health? What about the ethernet stats under network interfaces?
All the 4 drives shows the same, and zero errors so far,
this is disk 1, (all 4 showing the same)
Model: ST2000DL003-9VT166
Serial: 5YD7HXEB
Firmware: CC3C
SMART Attribute
Spin Up Time 0
Start Stop Count 9
Reallocated Sector Count 0
Power On Hours 567
Spin Retry Count 0
Power Cycle Count 9
Reported Uncorrect 0
High Fly Writes 0
Airflow Temperature Cel 30
G-Sense Error Rate 0
Power-Off Retract Count 3
Load Cycle Count 9
Temperature Celsius 30
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Head Flying Hours 253248451641911
ATA Error Count 0
The Ethernet status is 100 Mbit / Full-Duplex, MTU 9000 with static IP assigned.
looking at Network Erros [Ethernet 1] shows no errors to:
TX packets 8316086
TX errors 0
TX dropped 0
TX overruns 0
TX carrier 0
RX packets 1954135
RX errors 0
RX dropped 0
RX overruns 0
RX frame 0
Collisions 0
Network Errors [Ethernet 2]
TX packets 1558
TX errors 0
TX dropped 0
TX overruns 0
TX carrier 0
RX packets 54605
RX errors 0
RX dropped 0
RX overruns 0
RX frame 0
Collisions 0
I can't really spot anything wrong, tried unchecking jumbo frames close to hundreds of times now with either one of the ports active or both, lowering to 1500 MTU didnt help just lowered the speed from 10 Mb/s to average 7, max 9 Mb/s :S
