NewL1fe
Apr 01, 2012Aspirant
Slow transfer speed and way to much bugs..
Hello Im new with ReadyNas, but been using it for sometime now tho :) Ive got loads of bugs so far and the rescan for ReadyDLNA has been bugging constantly and now it's totally not working, from...
NewL1fe
StephenB wrote: You are not running gigabit ethernet . Assuming there is no typo in the quote, 10 Mbyte is a good speed. You should keep jumbo frames off, as they do not work with 100 mbit ethernet.
The Ethernet status is 100 Mbit / Full-Duplex, MTU 9000 with static IP assigned.
BTW, your other stats look fine.
Can you tell us more about your switches and routers (giving model numbers and connection information)?
True, the NAS only do 100 Mb/s Ethernet. My bad. (but 10 mbs, when reading some other topics that they pushed it to 70-90 Mbs makes me feel sad about 10 Mbs)
The Router is Linksys WRT120N both NAS ports connected to, My pc is also connected to the router.
The Switch is Cisco Small Buisness 1000-08, Ive connected my Samsung smart TV, PS3 and other pcs to that one.
But I connected both the NAS and my pc to the router and still pretty crap speed as I said earlier, 10 Mbs.
Not really sure, but seems like I gotta live it -.- my biggest and most annoying problem now is the DLNA not working and have to move all my files out cus I dont wanna enable SSH root thingie since then the support wont help me, how great.
