NewL1fe
Apr 01, 2012Aspirant
Slow transfer speed and way to much bugs..
Hello Im new with ReadyNas, but been using it for sometime now tho :) Ive got loads of bugs so far and the rescan for ReadyDLNA has been bugging constantly and now it's totally not working, from...
Apr 01, 2012Guru - Experienced User
The SF100D-08 is also 100 mbit. (the "F" stands for "fast ethernet", the SG100D-08 is the gigabit version. You need to be careful on the model numbers...
NewL1fe wrote: Oh sorry I meant to write Cisco Small Business SF100D-08 for the switch :p
The NAS is much faster than your network. To get the most out of it, you should buy a gigabit switch to replace the SF100D-08, and connect all your gear to it. You should also check your cables (you need at least cat5e for gigabit).
