mhurler
Feb 12, 2017Aspirant
SMB quits working
Hi! Since yesterday I have increasing problems with my ReadyNAS 516. It runs 6 3TB harddisks, in X-RAID 6. It operates under OS 6.6.1. It has worked for quite a while since the update to 6.6.1 ...
JennC
Feb 13, 2017NETGEAR Employee Retired
Hello mhurler,
Can you try disabling AntiVirus from the admin page when you get chance and see if you get the same results?
mhurler
Feb 14, 2017Aspirant
Hello JennC,
thanks for your response.
I have now disabled AntiVirus on the NAS and will observe whether it runs stable again.
I will revert back in a couple of days.
Best regards,
Michael
- JennCFeb 14, 2017NETGEAR Employee Retired
Hello mhurler,
You're most welcome. Just report back the results, we'll also see if others who get the same issue can share their resolution or ideas,
- mhurlerFeb 19, 2017Aspirant
Hi JennC,
After almost a week without AV the problem did not reoccur.
It would just be really good to use AV again. Any idea when the next stable release might be published?
Michael
- mdgm-ntgrFeb 19, 2017NETGEAR Employee Retired
There is ReadyNASOS 6.7.0-T158 (Beta 1). There is no ETA as to when the production release will occur at this time.
