Blanker-2's avatar
Sep 07, 2018
SMB1 solution?
Hi guys,  I'm assuming my RN312 unit (bought in 2017) is using SMB1 but how do I know?  I was doing a fresh wipe of my readnas system at the same time as upgrading from Windows 7 to Windows 10.  I could not connect to my shares on Win10 so after reading some other posts on here, I created a user in the nas with the same name as my windows profile and the same password as my user on the nas (I just use admin on the nas).  This worked but I also see the volume shares and other folders - no big deal.  I'm assuming that my nas is using SMB1?  So what are my options here?
1. Every time I want one of my computers in my home to access the nas will I have to create another user on the nas with the same name as the profile of that windows user?  What about cell phones, my dune, etc?  This sounds pretty undesirable.
2. I understand this is a Windows thing but is Netgear providing any solutions?
3. I saw the SMB plus app on my readynas, would this help?
Should I be looking for a new NAS?
  • A new ReadyNAS is going to be running the same firmware as your RN312, so getting a new unit is not the solution.
    The RN312 runs ReadyNAS OS 6 which has support for SMB3 and is getting updates with newer versions of the samba project (used for SMB service) over time.
    Make sure the NAS is in the same workgroup as your PC.
  • StephenB's avatar
    If you were using SMB1, then this trick wouldn't have worked.
    You are using SMB3. The issue you had initially was that Microsoft is also making adjustments to limit guest access (along with deprecating SMB1).  The account you created in the NAS solves this.
    On the ability to see the full volume - there are two possible reasons for this:
    • You might be using the NAS admin account credentials in the PC.  You can look in the windows credential manager to check this.
    • Your new NAS user might be in the NAS admin group.  If that's the case, you can shift that user to the users group.
    Or of course leave it as it is.
    • powellandy1's avatar
      powellandy1
      Virtuoso
      Having done a couple of fresh Win10 installs and ReadyNAS factory resets recently I can echo what mdgm and StephenB have said.
      I have always needed to do two things:
      1) On the NAS - make sure the workgroup is set to the workgroup name you use in Windows
      In ReadyNAS -> System -> Settings -> Click on SMB -> Change Workgroup name WORKGROUP to whatever you use. I also tick the Legacy Windows Discovery box as I have a few Win7 media centres.
      2) In Windows type Credential Manager into the search box (or find it in the old control panel) -> Select Windows Credentials at the top -> Select Add Windows Credential -> network address is name of NAS (set during inititalisation and on overview screen in ReadyNAS OS) and then username and password to admin and whatever your password is.
      This has always worked for me. Hope it helps.
      Andy
      • Blanker-2's avatar
        Blanker-2
        Guide
        Thanks everyone.  The nas is on the same worgroup as my pc., Windows credentials manager already has the nas in there, and my new nas user is in the users group, not Admin. That's fine though.  I think I was messing around with the access setting of the share.
        So if it seems I am using SMB3, and this is a Win10 issue, as far as accessing the share from 3 other computers in my house, I need to add a new user to the nas for each machine I want to connect to it?
  • schumaku's avatar
    schumaku
    Blanker-2 wrote:
    ..., I created a user in the nas with the same name as my windows profile and the same password as my user on the nas (I just use admin on the nas).
    A user is to identify the user - not a specific system. Ideally, users are combined into groups with similar/same access rights. And the shared folder access is based on groups, not individual users.
    An exception might be Dune or other media players potentially using DLNA/UPnP AV - in DLNA, there is no user access right design, so watch your steps.
    ReadyNAS OS 6 and most consumer NAS have the share enumeration wide open, this will allow to browse the shared folders by using a non-authenticated connection. The competition has introduced controls to the readily available SAMBA "access based share enum" with recent updates.
    Amazingly (not so...), Netgear promoting ReadyNAS more for the business environment is always behind - my requests to add these controls to OS 6 were ignored - there it went your business, Netgear.
    The SMB plus app has controls for the SAMBA "hide unreadable" and "hide unwriteable" affecting (sub-)folders and files only, so it's only a part of what you are behind.
    Edit: All this is independent of the SMB 1.0, 2.0, 2.1, or 3.0 protocol level used to access the NAS.
      Blanker-2
      Guide
      Thanks for the help. I'm not sure I understand all of what you are saying. I need a crash course on user controls. I use my 312 in a home environment, mainly to stream movies to my dunes throughout the house via smb, not dlna. I also take advantage of btrfs self healing for my repository of personal files that I share on the network.
      • Sandshark's avatar
        Sandshark
        Sensei
        If you are accessing the NAS by name, try switching to IP address.  I had to do that after the latest Windows 10 update.
ProSupport for Business
