sevilla315
Aug 12, 2018Aspirant
SMB1/2 access problems
Hi all,
A few months ago I had some problems with the SMB1.0 problem after some Microsoft updates and I found some threads on here advising a few things here : https://community.netgear.com/t5...
sevilla315
Actually after I uninstalled the nfs client I can't connect to the raid at all - can't map a drive, nor via http/s.
However when I had the nfs client installed, sometimes on restart when I clicked on a mappwd drive it couldn't connect, but not all of them.
I initially thought it was that I didn't have nfs access on the raid, which I gave and was able to create mounts to the raid, but then on restart some of these didn't connect, trying to mount them again just failed
The laptop where I didn't do any changes/installs, works consistently and on restart. Did Microsoft do something to allow backward compatibility with smb1?
sevilla315
I guess I will reinstall nfs client again, even if it's a bit flaky.
If I upgrade to OS6, is there anything I have to do on the Windows side, and are there any problems using this as I've had with nfs?
I'll have to copy off all the data (probably 1.2TB) to some external drive so I can do this upgrade.
Thanks
