Youri78
Feb 09, 2018Aspirant
smbd: memory corruption
Hello My ReadyNAS 104 is becoming unresponsive frequently. I have to unplug the power cable to restart it. I discover many memory corruption errors before the crash in smbd.log: [2018/02/08 15:29:...
Feb 09, 2018Guru - Experienced User
wrote:
This device is too old to get the Netgear support.
Perhaps too old to get free support, but not too old to get paid support via my.netgear.com.
Note the hardware warranty is 3 years, so it might still be covered. Though the memory issue could be software related.
What services do you have enabled, and what apps are you using?
Youri78
I have no app installed and I'm not using iSCSI, backup or cloud features.
The list of services: SMB, HTTP, HTTPS, SSH
I use Active Directory for authentication.
- mdgm-ntgrFeb 11, 2018NETGEAR Employee Retired
Do you use snapshots?
Are quotas enabled on your data volume?
- Youri78Feb 12, 2018Aspirant
Hi,
Snapshots are in not enabled on the shares:
-Snapshot management : Smart
-Snapshot schedule: Never
-Allow Snapshot Access: No
At the volume level:
-Snapshot prunning: 95%
Quotas are not enabled at volume or shares levels.
But Checksum is enabled at volume level.
- mdgm-ntgrFeb 12, 2018NETGEAR Employee Retired
Can you download your logs (see the Sending Logs link in my sig)?
Could you then run the memory test boot menu option?
