pravp
Jul 29, 2015Aspirant
Snapshot contains old data on Pro 6 4.2.27
I have 2 x ReadyNAS Pro 6 that service our office. A Snapshot is taken on the primary NAS each day at midnight and the secondary NAS pulls a backup off the snapshot shares (i.e. sharename-snap) via r...
mdgm-ntgr
Jul 29, 2015NETGEAR Employee Retired
Have you tried deleting the snapshot, rebooting then taking a new snapshot?
pravp
Aug 01, 2015Aspirant
just managed to try that as the unit is a production unit and had to wait for the weekend. Deleted, then rebooted and did a snapshot but result was the same, OLD Data.
Where is the snapshot data saved? is there a way in which I can SSH in and delete the cache somehow?
- StephenBAug 01, 2015Guru - Experienced User
The ReadyNAS software maintains snapshot status in its database, and will get out of sync if you delete the snapshot via SSH (unless you also know how to remove the info from the database manually - which I don't).
- mdgm-ntgrAug 02, 2015NETGEAR Employee Retired
I think you are referring to OS6 which has a database that stores info on snapshots. OS4 doesn't have such a database.
- StephenBAug 02, 2015Guru - Experienced User
Yes, my mistake. I apologize for any confusion created.
