pravp
Jul 29, 2015Aspirant
Snapshot contains old data on Pro 6 4.2.27
I have 2 x ReadyNAS Pro 6 that service our office. A Snapshot is taken on the primary NAS each day at midnight and the secondary NAS pulls a backup off the snapshot shares (i.e. sharename-snap) via r...
mdgm-ntgr
Aug 02, 2015NETGEAR Employee Retired
StephenB wrote:
pravp wrote:
Where is the snapshot data saved? is there a way in which I can SSH in and delete the cache somehow?
The ReadyNAS software maintains snapshot status in its database, and will get out of sync if you delete the snapshot via SSH (unless you also know how to remove the info from the database manually - which I don't).
I think you are referring to OS6 which has a database that stores info on snapshots. OS4 doesn't have such a database.
Aug 02, 2015Guru - Experienced User
Yes, my mistake. I apologize for any confusion created.
