pravp
Jul 29, 2015Aspirant
Snapshot contains old data on Pro 6 4.2.27
I have 2 x ReadyNAS Pro 6 that service our office. A Snapshot is taken on the primary NAS each day at midnight and the secondary NAS pulls a backup off the snapshot shares (i.e. sharename-snap) via r...
pravp
Aug 02, 2015Aspirant
mdgm, sorry for the noob question but don't the volumes get mounted each time the NAS reboots? What do you mean when you say that was then when the volume was last mounted? Is it possible to unmount and remount the volume to fix the issue?
I will have to wait until after hours to try the firmware downgrade, will also give that a shot. Managed to download the old firmware.
mdgm-ntgr
Aug 02, 2015NETGEAR Employee Retired
It would be mounted each time it is booted but the log indicates that last happened back in June.
If the services are stopped first then the volume could perhaps be unmounted and mounted, but a reboot would be easiest and the best way to do it.
- pravpAug 02, 2015Aspirant
thanks mdgm, i did reboot the unit after that the volume would have been remounted but as I reported earlier there was no change to the snapshots. Only course of action now is a firmware downgrade, I will get back after I have tried that.
