Muttley__
Dec 16, 2017Aspirant
Snapshots not working RN104 - Firmware 6.9.1
Snapshots on my RN104 have not been working for a while and I was hoping to spend some time fixing them over christmas can anyone please advise, I am currently on firmware revision 6.9.. The sys...
Muttley__
Thanks, I checked out the logs and there were not recent errors and no entries with snapshots in then :(
Dec 16, 2017Guru - Experienced User
Did you try creating a manual snapshot?
- Muttley__Dec 17, 2017Aspirant
Yes, I now have a mixture of smart and custom snapshot and none of them appear to be working :(
- msqDec 17, 2017Apprentice
If you have ssh enabled and you feel comfortable in linux command line - you can check the snapshost set up on a system level.
Once connected - navigate to
/YourVolumeName/._share/YourShareName/
and check two files
custom_snapshot_management.conf custom_snapshot_schedule.conf
In the first file you will find basic set up, including 'enabled' flag. See sample from my box below:
enabled = yes retention_rule = lifetime lifetime = 5184000 number = 30 nonempty_snapshots = yes prev_versions = no
In schedule conf you will see something that will match the hour/week map from the front end
..........1.....1.....1. ..........1.....1.....1. ..........1.....1.....1. ..........1.....1.....1. ..........1.....1.....1. ..........1.....1.....1. ..........1.....1.....1.
Can you please confirm it is enabled and you have something more than only dots in the schedule file?
Additionally - you can check if your cron daemon is running
- StephenBDec 17, 2017Guru - Experienced User
Neither of those are manual snapshots. Try clicking the settings wheel for a share, and then click on the snapshot button. It will prompt you for a snapshot name. Then see if the snapshot is successfully created.
- Muttley__Dec 18, 2017Aspirant
Hi,
Yes that appears to have worked
