Muttley__
Dec 16, 2017Aspirant
Snapshots not working RN104 - Firmware 6.9.1
Snapshots on my RN104 have not been working for a while and I was hoping to spend some time fixing them over christmas can anyone please advise, I am currently on firmware revision 6.9.. The sys...
Muttley__
Dec 17, 2017Aspirant
Yes, I now have a mixture of smart and custom snapshot and none of them appear to be working :(
Dec 17, 2017Guru - Experienced User
Neither of those are manual snapshots. Try clicking the settings wheel for a share, and then click on the snapshot button. It will prompt you for a snapshot name. Then see if the snapshot is successfully created.
- Muttley__Dec 18, 2017Aspirant
Hi,
Yes that appears to have worked
- StephenBDec 18, 2017Guru - Experienced User
Muttley__ wrote:
Hi,
Ok. That says the issue isn't with the file system, it has to be something else that is triggering it.
Do you have disk spindown enabled? If so, check the power settings, and make sure that "spin up disks to take scheduled snapshots" is checked.
If that setting is checked, then disable spindown for a bit, and see that changes the behavior.
- Muttley__Dec 21, 2017Aspirant
I looks like this solved it thank you :smileyhappy:
