tjsnow
Mar 25, 2016Aspirant
Snapshots using 1tb of storage on 314, but none in timeline
I currently show that ove 1TB of storageis being used by snapshots, however no snapshots show up on my timeline. I am trying to clear these out, becuse I don't even use snapshots any more. I have looked through the forums, and one person had an admin PM them with a solution (which didn't help me). Another offered the solution below, and while that worked for the original poster, it has not resolved my problem. I am trying to avoid any OS reinstall, because of the confugration needed to get back up and running. Is there a simple way to kick off the snapshot upgrade procvess or clear these out?
Solution that did not work for me...
Original Post with possible solution
# touch /.force_snapshots_upgrade # systemctl restart readynasd
I have deleted the snapshot and the expected space has been freed up.
I would suggest keeping volume usage to 80-85% or less and scheduling a weekly balance.
You may also want to schedule a defrag.
Scheduled volume maintenance should be scheduled to run at a time when you are not using the NAS much.
- JennCNETGEAR Employee Retired
- mdgm-ntgrNETGEAR Employee Retired
If you still have space used by snapshots after following JennC's suggestion please send in your logs (see the Sending Logs link in my sig).
- tjsnowAspirant
Ok I have looked at all the solutions I can find. I am now going to include scren shots, hopefully this will help.
My System Storage showing that over 1tb is wasted on snapshots:
Data page showing that there are 0 (zero) snapshots:
When I try to delete using the recovery option, it too show that there are no snapshots (checked every folder):
I am not sure what else to do. So MDGM, I have sent my logs in with a link.
Thanks...
Thanks for the logs.
The logs show a snapshot is still present for a share you deleted. I have sent you a PM.
