tmotu
Nov 29, 2011Aspirant
Snow Leopard and AFP issue NV+ 4.1.8
Hi all. I started having general problems with AFP in the last couple of weeks. I have an NV+ running 4.1.8. I upgraded it to that last week, in the hope that it would resolve the AFP problem first...
mdgm-ntgr
Dec 12, 2011NETGEAR Employee Retired
Going back to 4.1.7 should work, but you'd no longer be able to use it with Mac OS X 10.7 Lion clients.
What router are you using? I've had no problems with my ReadyNAS used with the Airport Extreme Base Station.
Do you still get the problem if you connect over ethernet?
Could you try a direct-connection?: http://sphardy.com/web/readynas/how-to-direct-connect-to-your-readynas/
