tmotu
Nov 29, 2011Aspirant
Snow Leopard and AFP issue NV+ 4.1.8
Hi all. I started having general problems with AFP in the last couple of weeks. I have an NV+ running 4.1.8. I upgraded it to that last week, in the hope that it would resolve the AFP problem first...
tmotu
Dec 13, 2011Aspirant
I haven't connected directly to the NAS, the closest I've come is using a wired connection through a switch. The switch is an SMC SMC8508T, which is unmanaged. The Layer 3 router that I'm using is an Airport Extreme 802.11n (2nd Generation), which is currently running the 7.6 firmware. I specify because I have a Wifi router that I use strictly as a WAP. That is, it's on the same subnet as the LAN behind the Airport Extreme, and performs no routing. I have tried two routers in this capacity, with the same issues.
Since I'm currently not supporting any Lion clients, going back to 4.1.7 feels like the easiest solution to this problem.
(Rudimentary diagram)
edited to format the "diagram"
airport extreme
SMC switch
NV+ | Windows 7 PC
d-link dir-825 B1 (2.06NA)
wired and wireless clients
