ToAmLo
Oct 01, 2014Aspirant
[SOLVED] How to purge deleted shares? #23972766
Hello, In the process of integrating in my office network a new RN 102 I found expedient to create on the RN 102 three shares to where I could copy data to move it from a RN NV+ to a RN Duo. The co...
- Oct 20, 2014The issue has been successfully solved by Netgear support, by remote access. My thanks to everybody for the help and tips, especially to the Netgear people both on the forum and support.
ToAmLo
vandermerwe wrote: Did you have continuous protection (snapshots) active on the 3 shares on the 102?
I don't remember disabling it so I think it's safer to assume that I did, but no snapshots show on the timeline so either I deleted them (or got deleted together with the shares) or I can't see them.
You ought to update the firmware on the NV+.
I did update it to the latest RAIDiator 4.1.13 but I had issues with the share security mode so I downgraded to 4.1.8 to get the old security mode back.
