ToAmLo
Oct 01, 2014Aspirant
[SOLVED] How to purge deleted shares? #23972766
Hello, In the process of integrating in my office network a new RN 102 I found expedient to create on the RN 102 three shares to where I could copy data to move it from a RN NV+ to a RN Duo. The co...
- Oct 20, 2014The issue has been successfully solved by Netgear support, by remote access. My thanks to everybody for the help and tips, especially to the Netgear people both on the forum and support.
vandermerwe
Oct 02, 2014Master
1. Share security mode is not advised anymore. You should change to user security mode.
2. It is possible that when you deleted the shares the snapshots were not deleted. How do you view the timeline if the shares were deleted?
You have a couple of possible solutions:
1. If you have all the data in the shares securely on another device, you could factory default the 102, recreate the shares then copy the data back. Then factory default the nv+ and redo the backup. I would suggest backing up each share on the 102 to a matching share on the nv+ rather than all into one share. It's simpler. What are you doing with the duo?
2. You could contact support.
