ToAmLo
Oct 01, 2014Aspirant
[SOLVED] How to purge deleted shares? #23972766
Hello, In the process of integrating in my office network a new RN 102 I found expedient to create on the RN 102 three shares to where I could copy data to move it from a RN NV+ to a RN Duo. The co...
- Oct 20, 2014The issue has been successfully solved by Netgear support, by remote access. My thanks to everybody for the help and tips, especially to the Netgear people both on the forum and support.
ToAmLo
Oct 02, 2014Aspirant
Thank you for the tips, I'm currently backing each share on the 102 to a matching share on the NV+ as you suggested in order to have the data backed up as soon as possible.
As we expect to keep working for a long time with a customer, we decided to allocate the whole capacity of the Duo (1GB) for his data so that we don't have to worry about running out of space any time soon.
I still would like to reclaim the wasted 300 GB from the 102 without having to go the trouble and time of a factory default and restoring of the remaining 670 GB. Before I try contacting support, any further tips?
