Retired_Member
Aug 24, 2011[solved] NVX won't boot - stuck at "installing addon"! case
Hi I would really appreciate some help getting my NVX going again. I made the mistake of attempting to install super-poussin's uTorrent add-on. My NVX is now stuck at "Booting...Installing a...
Retired_Member
Aug 24, 2011Hooray!
Thank you de niro, it's booting!
Now, please can you explain for the benefit of others, how you did this?
Is it something a user can do with SSH (putty), or some Tech support magic?
If users can do it, what are the steps?
Thanks again.
Thanks again.
