Retired_Member
Aug 24, 2011[solved] NVX won't boot - stuck at "installing addon"! case
Hi I would really appreciate some help getting my NVX going again. I made the mistake of attempting to install super-poussin's uTorrent add-on. My NVX is now stuck at "Booting...Installing a...
Retired_Member
Aug 24, 2011
mdgm wrote: You may wish to try a OS/firmware re-install via the boot menu.
Thanks for the suggestion, but it didn't fix it. Can you think of something else?
