Retired_Member
Aug 24, 2011[solved] NVX won't boot - stuck at "installing addon"! case
Hi I would really appreciate some help getting my NVX going again. I made the mistake of attempting to install super-poussin's uTorrent add-on. My NVX is now stuck at "Booting...Installing a...
mdgm-ntgr
Aug 25, 2011NETGEAR Employee Retired
That would be a .remove script in /etc/frontview/addons for each add-on installed.
If you use SSH, you can remove an add-on by running e.g.
sh /etc/frontview/addons/xxxxxx.remove
