blacky1
Dec 31, 2013Tutor
[Solved] ReadyNAS 104 - 6.1.5 USB3 problem
Logging in to the ReadyNAS this morning I was prompted that firmware 6.1.5 was available. After reading the release notes I happily clicked upgrade. On reboot I noticed my external backup USB3 dri...
blacky1
Jan 06, 2014Tutor
Thanks for the notification super-poussin.
I'm running the update now. I'll report back after I've run some tests.
EDIT: I can confirm that with firmware 6.1.6-RC3, connecting the external backup USB3 drive back to the top rear USB port now shows the drive mounted and recognised by FrontView. The Backup settings -> 'test connection' option now shows the drive as found. I have not actually run a backup but I have no reason to think it will fail now the drive is connected.
Thank you for the quick fix and the excellent support I've received from various members in this thread and via PM.
