_Thumper_
Nov 18, 2012Aspirant
[SOLVED] ReadyNAS Duo v2: cannot turn on! - FW 3.5.6
I received my Duo as a present just one week ago, I only had the time to mount a couple of disks on it and put some files to test the ReadyDLNA feature. Everything went fine so and I decided to give a...
mdgm-ntgr
Nov 18, 2012NETGEAR Employee Retired
Upon a factory default the NAS automatically downloads the latest firmware and installs it. It can take a few updates to update the U-Boot so if you'd updated to 5.3.7 the U-Boot would have been updated and you most likely wouldn't have started this thread. Most likely you have an old U-Boot. If the Duo v2 was only recently purchased ask the friend who gave the Duo v2 to you if it's still within the return period for the reseller they purchased it from. If so they could exchange it for another new unit. If not, NetGear would need to RMA the unit and you'd get a refurb via RMA.
