_Thumper_
Nov 18, 2012Aspirant
[SOLVED] ReadyNAS Duo v2: cannot turn on! - FW 3.5.6
I received my Duo as a present just one week ago, I only had the time to mount a couple of disks on it and put some files to test the ReadyDLNA feature. Everything went fine so and I decided to give a...
_Thumper_
Hi,
The Duo was purchased on 13th October and delivered at the beginning of November (it was a present from my wife). It was brought on an online store here in Italy and I will immediately check if we can still apply for a new one.
I hope Netgear will not propose me a refurbished unit since we did not pay our money for a brand new to get a "cleaned from factory" just one week later. We could have done a better deal buying directly a refurbished one from eBay (warranty included).
I will keep you informed, thanks for the instantaneous reply ;)
