fneurieser
Aug 10, 2014Aspirant
[SOLVED] RN102 - Problems?! #23673790
Hello, I'm not sure how to go on. I've a RN102 with 2 3TB WD RED disks (WD30EFRX) inside. Yesterday I tried to setup for the first time but I got an IP different from my home network. So I changed i...
fneurieser
mdgm wrote: Maybe you have a bad disk then.
and what did you mean when saying
I think i know what the issue is and if it is what I suspect it is it should be a quick fix.
