fneurieser
Aug 10, 2014Aspirant
[SOLVED] RN102 - Problems?! #23673790
Hello, I'm not sure how to go on. I've a RN102 with 2 3TB WD RED disks (WD30EFRX) inside. Yesterday I tried to setup for the first time but I got an IP different from my home network. So I changed i...
Aug 10, 2014Guru - Experienced User
Me too. I use address reservation in my router extensively - using reserved addresses for everything that is regularly connected to my network. It simplifies both port forwarding and troubleshooting. And if I need to change equipment, or change to a new IP address space, everything still connects properly without needing to be reconfigured before the changeover.
mdgm wrote: ...Personally I much prefer setting a static I.P. in the router's settings than doing it in the Dashboard of the NAS...
It gives you all the benefits of static addresses, and all the benefits of DHCP too.
