cguers
Mar 26, 2013Aspirant
[SOLVED] SSH rsync error
I just wanted to post this as there may be others experiencing the same issue. 8) I have two NAS devices, a PRO and an ULTRA, on separate locations and I am doing an rsync between the devices ove...
kossboss
Mar 27, 2013Guide
This is a typical issue I see with ssh, its not really a readynas issue. It just using a pretty bad method to see if your being hacked. It has the ssh key and the some other info, and its not matching. After you fix - did the problem persist? Did you add the key of the source nas to the authorized list of the destination (from the rsync share settings menu)?
