cguers
Mar 26, 2013Aspirant
[SOLVED] SSH rsync error
I just wanted to post this as there may be others experiencing the same issue. 8) I have two NAS devices, a PRO and an ULTRA, on separate locations and I am doing an rsync between the devices ove...
cguers
Mar 27, 2013Aspirant
@kossboss
After removing the known hosts files, the problem with the "man in the middle" the was fixed. :D
Now I am getting some timeouts on long sync jobs (multi-GB shares), but I believe that is due to something else. Possibly some issues with the ISP on either end. This is the error message I see now in the log file:
INCREMENTAL Backup started. Wed Mar 27 09:42:21 ART 2013
Job: 006
Protocol: rsync
Source: [media]/
Destination: <remote host>:/media
sending incremental file list
<file 1>
<file 2>
<file 3>
Read from remote host <remote host>: Connection timed out
rsync: writefd_unbuffered failed to write 4 bytes to socket [sender]: No child processes (10)
rsync: connection unexpectedly closed (4006 bytes received so far) [sender]
rsync error: unexplained error (code 255) at io.c(605) [sender=3.0.9]
Backup failed.
