flattened
Jan 20, 2017Apprentice
Sorry folks but... what is ReadyDR?
We'd love to have a solution where a NAS312 is on premises A and an identical NAS312 is at premises B and they are, if not exact clones of each other then at least within hours of each other so that ...
- Jan 22, 2017
flattened wrote:
I was going to use a 2TB share size. The nightly full backup is (to use an easy figure) 200GB (of which in reality only 1 GB or less of data actually changes) and I was advised that I'd be lucky to get a week's worth of snapshots.
Does this ring true?
If the full backup is a single file, then rsync would rewrite the entire file - taking a fair amount of time over the network, and also shifting the previous nightly backup file to the snapshot (adding 200 GB to the snapshot space).
If the backup is large set of files, then only the files that changed are rewritten, and there is much less increase in the snapshot size. It'd be more than the 1 GB of changed data (since unchanged data in the changed files is also re-rewritten by rsync), but not the full 200 GB.
flattened wrote:
As a result I've created an iSCSI LUN of 1.5TB that the WSB will see as a dedicated device that it can indeed do incremental backups to, that I can also set to also snapshot nightly.
So, looking further, should the decision be made to get another offsite NAS for belt&braces purposes I'd use ReadyDR on this source LUN to a share on the offsite box???
ReadyDR generally works well for LUNs. Updates to blocks on the LUN on the source will increase the local snapshot size needed on the source of course. ReadyDR will migrate those changed blocks to the destination NAS efficiently.
How well this works with your software depends on how many blocks of the LUN are re-written when the WSB backup runs. If the WSB re-writes unchanged blocks, then it won't work very well. I'd try it locally first, and where you have more bandwidth to work with (and easier access to the destination machine).
Jan 20, 2017Guru - Experienced User
The ReadyDR faq is here: http://kb.netgear.com/31224/ReadyDR-FAQ?cid=wmt_netgear_organic
If your goal is to mirror what's on the NAS, so you can quickly switchover to the backup:
-ReadyDR and Replicate won't do that. They will back up the primary NAS, but the destination repositories on the remote NAS aren't shares that you can immediately use. You'd have to restore them back, which will result in down time. And you will need enough disk space to do the restore (That is, you'd need enough free space on the destination to hold both the backups and the restored source shares).
-Rsync backup jobs will do what you want, but the snapshots won't match. (Note you can use snapshots on the destination, and you could then see older (backed up) versions of a file But the snapshots you see won't match).
The net here is that ReadyDR and Replicate are designed for backup, not "cloning". Like you, I am wanting cloning, so I am sticking with rsync.
One caveat: rsync is not great way to back up isci luns over the WAN. If you are using them, you probably do need ReadyDR, since it is only transfering blocks in the luns that have changed.
flattened
Thankyou, that is a great explanation for me on rsync vs everything else.
What happens with ReadyDR destination if the source is completely destroyed? I can't wrap my head around the "backs up snapshots only" idea. How can you recover only snapshots from unit B if the original is gone. As snapshots are only changes to the original over time, are these the snapshots that are created after an initial seed to box B of the LUN on box A for example? Otherwise I cannot understand how you can recover only snapshots when the original data is destroyed as they snapshots would have nothing to refer back to.
Andy.
