dozens
Mar 19, 2013Aspirant
Speed dealing with Folder with thousands of subfolders
So this is super general, but I have a ReadyNAS Duo 2150, the old one, and it's main use is serving music to my Macbook Air. It's painfully slow when say, playing one song and then doing anything else...
Apr 16, 2013Guru - Experienced User
So you have the itunes database on your PC, and it is very slow when you add/delete songs from iTunes?
Or is it very slow when you add/delete songs using SMB/CIFS or AFP???
