dozens
Mar 19, 2013Aspirant
Speed dealing with Folder with thousands of subfolders
So this is super general, but I have a ReadyNAS Duo 2150, the old one, and it's main use is serving music to my Macbook Air. It's painfully slow when say, playing one song and then doing anything else...
Apr 18, 2013Guru - Experienced User
Well, if the iTunes app is scanning through the folders, a slow WiFi connection might explain why that scan is taking so long.
BTW, is there any easy way you would tell if this happens with a smaller music folder? (e.g., one w/o thousands of subfolders). Maybe saving off your iTunes Library, and building a new one with a smaller music folder?
