MullenNG
Aug 15, 2017Aspirant
Spinning up shortly after each Spinning down
I just bought a new ReadyNAS 214 and updated to latest firmware (6.7.5). I setup spin-down (5 minutes, all the time) as I rarely use it (mainly only for storage and back-up purpose). However, I notic...
- Sep 16, 2017
Just want to close this topic as the issue is solved.
I contacted customer service, and instructed by engineer to install 6.8.1-RC1, which version fixed the issue.
Aug 15, 2017Guru - Experienced User
If Antivirus is enabled, you might try disabling it and see if that makes a difference.
Does it ever stay spun down for more than a few seconds?
MullenNG
No, AntiVirus is not enabled.
No. I enabled spindown since Aug12, 22:19:14, and I checked through the log, Best I could get is 25 seconds (3 times), and usually 15 seconds (278 times), and 5 seconds (234 times).
