MullenNG
Aug 15, 2017Aspirant
Spinning up shortly after each Spinning down
I just bought a new ReadyNAS 214 and updated to latest firmware (6.7.5). I setup spin-down (5 minutes, all the time) as I rarely use it (mainly only for storage and back-up purpose). However, I notic...
- Sep 16, 2017
Just want to close this topic as the issue is solved.
I contacted customer service, and instructed by engineer to install 6.8.1-RC1, which version fixed the issue.
MullenNG
No, AntiVirus is not enabled.
No. I enabled spindown since Aug12, 22:19:14, and I checked through the log, Best I could get is 25 seconds (3 times), and usually 15 seconds (278 times), and 5 seconds (234 times).
aks
Aug 16, 2017Virtuoso
You haven't said much about your network configuration, can we assume you've isolated the ReadyNAS and 'listened' to it or watched the display? How about pulling the network cable, does it stay spun down - I expect it will?
- MullenNGAug 17, 2017Aspirant
Tested, no, without network, still can only spin down for 15 seconds
- aksAug 17, 2017Virtuoso
Sorry, I don't have a RN214, but it should be easy for someone that does to check if their unit can spin down and stay that way for a while.... this will verify if it's a generic problem or some configuration issue with your setup.
