PACMAN7
Nov 10, 2022Tutor
Spinning wheel when trying to reset password on RN626 despite correct email and security answer
Can anyone help?
- Feb 16, 2023Thanks Stephen. I was connecting from a Mac with SMB. But I’ve managed to get the device up and running again now.
Nov 12, 2022Guru - Experienced User
Try doing an OS reinstall from the front panel instead. That will reset the password back to password.
It will also
- reset the NAS ethernet to use DHCP with no bonding
- disable volume quota (which can be re-enabled from the volume settings wheel).
See page 137 in the hardware manual for instructions:
- PACMAN7Nov 22, 2022Tutor
Thank you for the reply. I couldn't wait so wiped it and started again. I've now reached a point where another one of the Time Machine sparse bundles needs increasing and I'm back there again, trying to connect to this particular sparse bundle to no avail, so that I can delete it, and create a new, larger one. I never had to do this when I ran Apple Time Capsules. When they filled up, the oldest backup would be automatically removed by Time Machine to make way for the latest one. Which I'd assumed the Netgear NAS would also do—being advertised as a Time Machine product.
