cgehansen
May 15, 2013Follower
Squeezebox not connecting to LMS on reboot
Hi, I have a problem with LMS. When my Duo boots up after its timed overnight shutdown my Squeezebox can't connect to it unless I reboot my router (Linksys 4200) and restart the squeezebox reciever. T...
vandermerwe
May 30, 2013Master
When you reboot, does LMS see your squeezebox?
Also does the Duo have a connection through your router to any other machine and/or the Internet. Is this connection ok when it restarts?
What happens if you only reboot the router?
Have you tried reinstalling the duo firmware and LMS?
