craer87's avatar
craer87
ssd tiering
ok so looking in to if i can add some speed to me NAS i have 4) 10tb drives thinking about putting some ssd's in the last 2 bays still leaving me room to grow i have some 500g WD blue ssd both ...
  • StephenB's avatar
    Oct 31, 2018
    There is is an explanation on page 10 here: https://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_FlexRAID_Optimization_Guide.pdf
    Also here: https://kb.netgear.com/000049513/ReadyNAS-OS-6-9-Metadata-Tiering
    One ambiguity is the statement "The number of SSDs for the SSD tier should be equal to the number of drives in the RAID group."  I don't know if that is a suggestion or a requirement.
    Note that per the guide, you need to create an SSD tier for each RAID group in the volume.
    craer87 wrote:
    exp: does it take a high use file off the hdds and "MOVE" it to the ssd or is it a copy
    The SSD tier is not a cache.  Things stored on it are not duplicated on the mechanical disks.
    With 6.9.x firmware the tier only includes metadata, it does not include the actual files.  Note that in 6.10.x beta Netgear is expanding the use of the tier to include some files (data).  https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-10-0-T185-Beta-2/m-p/1651396#M10285
    craer87 wrote:
    and what MetaData . what exactly  is that on the nas
    "Metadata" is the on-disk structures used by the BTRFS file system to describe the files - among other things it includes the filenames, the organization of the files into folders and BTRFS subvolumes, file owners and permissions, and the location of the data in the files on the disks. The equivalent information in the ext filesystem is in "inodes".
ProSupport for Business
